Center Justify Text
Is it possible to center justify the text in the “Duration” and “Predecessors” columns? (Or any other column for that matter?)
I attached a screenshot and it’s really tough to read what’s going on with the text crammed together.
Screenshot%20from%202018-02-23%2008-38-56
No, text alignment is not yet configurable, sorry.
Hi Dmitry, if it’s not possible now, can you at least force left alligment in all columns? It should be enough to increase readability.
All left-aligned? Why? Numeric values must be right-aligned. Text values in English and most other cultures must be left-aligned.
What is requested here is the visual space or separator between values and it can be solved by padding which I hope to add soon.
Here is how it looks with padding
you’re right. padding would be enough.
