Hi… I have a bit of problem on how to remove the date tag on the top right corner when im exporting it to pdf… Please advise. Thanks.
The template is written in Java code, sorry. You need to edit and recompile it if you want to remove the date.
ok thanks for the info.
Perhaps just drawing a white rectangular over it would do the trick to some extent?
