Hello team,
I’m trying to import the xml file of MS Project format exported from QuickPlan application, but it does not work, nothing happens, Gantt Project stays white.
I’ve joined the xml file to this message. Residential_Construction_180523.xml (2.1 KB)
The attached file is not MS Project file. It is GanttProject file with .xml
extension instead of .gan
and no tasks inside. It can be opened directly in GanttProject with Project > Open.
I also tried this .xml, and it worked.
But I tried using a different file, it’s blank. Is there a right way to save the MS Project to xml that we might need to consider?
