Would it be possible to either change the default export path to a specific folder on the local machine via a registrty path or to change the default export path to the exact same folder as the gantproject file itself.
All of this, in the pdf export format.
Users will use Ganttproject for multiple project at the same time. I am 99% sure that they will end up overwriting files since it uses the last memorised saved location.
Using a local folder for each save would fix my problem. Is it something possible ?
Thanks.
