Is it possible to add a password for blocking the modifications in the diagram?
And is it possible to add base chart blocking? And work at the actual Gantt diagram?
Thank you for the answer
Best regards,
Best regards,
Can you elaborate on the use case? I don’t see where password might be useful. Let’s consider two scenarios of usage:
In my opinion, what could be useful in the scenario where you don’t trust to collaborators is ability to sign the file, so that it was possible to add some data but it would clearly break the signature.
With respect to this:
I admit I don’t understand the question. What do you mean when you say “base chart” and “actual Gantt diagram”?
Yes, the first proposal is better and for the base chart … It comes from the nature of project scheduling. First it is a base chart and then when you make a modifications during the project running we have some updates and the schedule can be different and by this function one can observe how it behaves.
Did you mean to say Baselines ? There is a button Baselines… above the chart which probably does exactly what you want.
