Phil Elliot: task titles in PDF export
I have a mac running catalina and I cannot get it to show task titles when I export to PDF
HELP!
How please? I cannot find a way to show task tiltes when I export to PDF
Can you please provide us with more details? Where do you expect to see the task titles and what do you actually get? A screenshot or the resulting PDF would help a lot.
SH V2.pdf (110.0 KB)
useless as it is
P
Can you please try changing the application font? Chances are that the one which is currently in use is not embeddable and thus won’t appear in the document.
I think it is fixed and it is all about the fonts
Phil
Hello Phil (as me !)
how did you fix it please ? I have the same pb (macOS Catalina) : no tasks title …
thanks
its all about the fonts - you need to reset the fonts
Phil
I’m was having the same problem using 3.1.3102. After fiddling around with the font settings in Preferences > Application UI and selecting “system font”, the task titles were again present in the exported PDF, though maybe not on the first try.
I’d love to see some documentation (maybe I missed it) and/or some input from the dev and/or support staff on this.
