What’s your ultimate goal? Printing on A0?
Yes, or comparable size
If printing on large format is the goal, it is better to export to PDF using an appropriate paper size (e.g. A0, see the screenshot with the export settings below). This will produce a scalable vector image. Print the 4th page of the result file (or save only that page to another PDF, or use tiling option which is available in some PDF viewers to print A0 output on tiled A4 pages.
[HouseBuildingSample.pdf|attachment]The result of A0 PDf export is attached.
HouseBuildingSample.pdf (132.5 KB)
Yep, that works.
Thank you.
