Project > Open, is broken on Manjaro KDE Linux
I actually managed to install it via Manjaro’s package manager, but I still get the bug in the above screenshot, and the log output still looks like it’s using the wrong version of Java. Not sure what to do… never been sure what to do with .tar.gz downloads, if you don’t have any advice I’ll try to look into it myself again…
/home/domarius/.ganttproject.d/logs/.ganttproject-20210320000527.log
GanttProject 3.0.3004
Settings file:
	is readable: true
java.class.path: :/opt/ganttproject/eclipsito.jar
java.home: /usr/lib/jvm/java-15-openjdk
java.ext.dirs: null
java.io.tmpdir: /tmp
java.runtime.version: 15.0.2+7
java.vendor: N/A
java.vm.name: OpenJDK 64-Bit Server VM
java.vm.vendor: Oracle Corporation
java.vm.version: 15.0.2+7
os.arch: amd64
os.name: Linux
os.version: 5.9.16-1-MANJARO
sun.java.command: com.bardsoftware.eclipsito.Launch --verbosity 1 --version-dirs /opt/ganttproject/plugins:~/.ganttproject.d/updates --app net.sourceforge.ganttproject.GanttProject -log true -log_file /home/domarius/.ganttproject.d/logs/.ganttproject-20210320000527.log
user.country: AU
user.dir: /home/domarius
user.home: /home/domarius
user.language: en
user.timezone: Australia/Brisbane
Mar 19, 2021 2:05:29 PM net.sourceforge.ganttproject.GPLogger log
INFO: Deleting old auto-save files
Mar 19, 2021 2:05:30 PM net.sourceforge.ganttproject.GPLogger log
INFO: Starting RSS check...
Mar 19, 2021 2:05:33 PM net.sourceforge.ganttproject.GPLogger log
INFO: RSS check finished
INFO: [GanttOptions] save(): finished!!
