Hi, How can I display a column with the % projected updated
I can’t say that I clearly understand the question, but if you meant task progress (or completion percentage which is the same) then you can show it, just like any other column, with “Manage Columns” action in the task table header context menu (right click)
Alo Dimitri, thank you for your attention. I am referring to the percentage planned on a certain date, to be compared to the% effectively completed and gauge the delay, or advance. I can not find this column,
You can’t find this column because there is no such column.
The only available feature in GanttProject which allows for comparing current state with planned is baselines. You can save a snapshot of the project and later compare task dates to the dates in the snapshot. That’s it. Baselines button sits above the Gantt chart.
Ok Dmitry, thanks a lot for the help. will be useful for sure.
