Hi there, I have used ganttchart in the past with no problems. I recently upgraded to the latest version and now I have a problem where the task notes overprint on the task date in a pdf export. This now happens with old projects and new projects.
I tried to downgrade to an old version of ganttchart but the problem still exists.
I my description was clear enough.
Thanks.
Sorry, no, it is not clear. Can you please share an example of the project file and PDF produced by export?
Hello Dmitry,
Thank you for your fast reply.
Attached is the PDF export file as well as an enlarged image of the
problem.
Thank you for your fine product.
Regards,
Gary
document.pdf (77 KB)
It is not the notes which are printed over the table, it is task name. I suppose that you have an option to show task names to the left of the task bar switched on.
I did not check, but most likely it is reproducible in any GanttProject version.
I submitted a new bug report: https://github.com/bardsoftware/ganttproject/issues/1603
We’ll try to fix it in the next update.
Perfect. Thank you. All is good.
