Hope all is well.
I have downloaded “ganttproject-2.8.9-r2335.zip” file on fedora os (Version fedora29).
Extracted files to “ganttproject-2.8.9-r2335” folder and changed ganttproject.bat file permissions to executable.
Running bat file gives below message
ERROR: error getting working directory name: no such file or directory
/home/petcare/Documents/ganttproject-2.8.9-r2335/ganttproject.bat: line 1: @echo: command not found
/home/petcare/Documents/ganttproject-2.8.9-r2335/ganttproject.bat: line 2: $’\r’: command not found
/home/petcare/Documents/ganttproject-2.8.9-r2335/ganttproject.bat: line 3: SET: command not found
/home/petcare/Documents/ganttproject-2.8.9-r2335/ganttproject.bat: line 4: $’\r’: command not found
/home/petcare/Documents/ganttproject-2.8.9-r2335/ganttproject.bat: line 5: SET: command not found
/home/petcare/Documents/ganttproject-2.8.9-r2335/ganttproject.bat: line 6: IF: command not found
/home/petcare/Documents/ganttproject-2.8.9-r2335/ganttproject.bat: line 7: $’\r’: command not found
/home/petcare/Documents/ganttproject-2.8.9-r2335/ganttproject.bat: line 8: SET: command not found
/home/petcare/Documents/ganttproject-2.8.9-r2335/ganttproject.bat: line 8: fg: no job control
/home/petcare/Documents/ganttproject-2.8.9-r2335/ganttproject.bat: line 9: $’\r’: command not found
/home/petcare/Documents/ganttproject-2.8.9-r2335/ganttproject.bat: line 10: SET: command not found
/home/petcare/Documents/ganttproject-2.8.9-r2335/ganttproject.bat: line 11: SET: command not found
/home/petcare/Documents/ganttproject-2.8.9-r2335/ganttproject.bat: line 12: $’\r’: command not found
/home/petcare/Documents/ganttproject-2.8.9-r2335/ganttproject.bat: line 13: fg: no job control
/home/petcare/Documents/ganttproject-2.8.9-r2335/ganttproject.bat: line 22: syntax error: unexpected end of file
When i run “java -version” from within unzipped folder, i get following
Unrecognized option: --version
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
When i drop one level to Documents folder running “java -version” gives
openjdk version “1.8.0_191”
OpenJDK Runtime Environment (build 1.8.0_191-b13)
OpenJDK 64-Bit Server VM (build 25.191-b13, mixed mode)
Where can i find installation instructions relevant on fedora?
On fedora can ganttproject be installed or i have to open by running bat file every time?
Thanks in advance.
