I have use 2.8 without any problems. I installed 2.99.2906 and when I start it I get this error message:
“java.net.ConnectException: Connection timed out: no further information Connection timed out: no further information”
I can contine to use the program.
The error log says:
"C:\Users\dany\ganttproject.log
GanttProject 2.99.2906
java.class.path: eclipsito.jar;C:\Program Files (x86)\GanttProject-2.99
java.home: C:\Program Files (x86)\GanttProject-2.99\runtime
java.ext.dirs: null
java.io.tmpdir: C:\Users\dany\AppData\Local\Temp
java.runtime.version: 11.0.7+10-LTS
java.vendor: BellSoft
java.vm.vendor: BellSoft
java.vm.version: 11.0.7+10-LTS
os.arch: amd64
os.name: Windows 10
os.version: 10.0
sun.java.command: com.bardsoftware.eclipsito.Launch --verbosity 4 --version-dirs plugins;~/.ganttproject.d/updates --app net.sourceforge.ganttproject.GanttProject
user.country: SE
user.dir: C:\Program Files (x86)\GanttProject-2.99
user.home: C:\Users\dany
user.language: sv
user.timezone: Europe/Berlin
okt. 02, 2020 9:41:26 FM net.sourceforge.ganttproject.GPLogger log
INFO: Options file:C:\Users\dany.ganttproject
Creating main frame…
- loading look’n’feels
no editor for column=2 class=interface javax.swing.Icon - loading options
- creating menus…
- creating views…
- changing language …
okt. 02, 2020 9:41:28 FM net.sourceforge.ganttproject.GPLogger log
INFO: Bounds stored in the options: java.awt.Rectangle[x=-8,y=-8,width=1936,height=1186] - finalizing…
Main frame created
INFO: Bounds after setVisible: java.awt.Rectangle[x=-8,y=-8,width=1936,height=1186]
Resizing window…
okt. 02, 2020 9:41:29 FM net.sourceforge.ganttproject.GPLogger log
INFO: Bounds after opening: java.awt.Rectangle[x=-8,y=-8,width=1936,height=1186]
okt. 02, 2020 9:41:36 FM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
okt. 02, 2020 9:41:36 FM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFO: scanning directory=C:\Program Files (x86)\GanttProject-2.99\runtime/lib/fonts
INFO: directory C:\Program Files (x86)\GanttProject-2.99\runtime/lib/fonts is not readable
okt. 02, 2020 9:41:38 FM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFO: scanning directory=/C:/Program%20Files%20(x86)/GanttProject-2.99/plugins/base/org.ganttproject.impex.htmlpdf/resource/fonts
INFO: directory /C:/Program%20Files%20(x86)/GanttProject-2.99/plugins/base/org.ganttproject.impex.htmlpdf/resource/fonts is not readable
okt. 02, 2020 9:41:38 FM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
okt. 02, 2020 9:42:11 FM net.sourceforge.ganttproject.GPLogger logToLogger
VARNING: java.net.ConnectException: Connection timed out: no further information
java.util.concurrent.CompletionException: java.net.ConnectException: Connection timed out: no further information
at java.base/java.util.concurrent.CompletableFuture.encodeRelay(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.completeRelay(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture$UniCompose.tryFire(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.postComplete(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.completeExceptionally(Unknown Source)
at java.net.http/jdk.internal.net.http.PlainHttpConnection$ConnectEvent.lambda$handle$1(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Caused by: java.net.ConnectException: Connection timed out: no further information
at java.base/sun.nio.ch.SocketChannelImpl.checkConnect(Native Method)
at java.base/sun.nio.ch.SocketChannelImpl.finishConnect(Unknown Source)
at java.net.http/jdk.internal.net.http.PlainHttpConnection$ConnectEvent.handle(Unknown Source)
at java.net.http/jdk.internal.net.http.HttpClientImpl$SelectorManager.handleEvent(Unknown Source)
at java.net.http/jdk.internal.net.http.HttpClientImpl$SelectorManager.lambda$run$3(Unknown Source)
at java.base/java.util.ArrayList.forEach(Unknown Source)
at java.net.http/jdk.internal.net.http.HttpClientImpl$SelectorManager.run(Unknown Source)"
