3.2: Adding new built-in column to task not working
  • Clicking on cogwheel
  • Clicking on eye of a built-in property like duration (eye not crossed out anymore)
  • Clicking Apply
    → The column is not added. Opening the setttings shows the eye crossed out again.
Funny:
  • Adding a new custom column works.
  • Custom columns in turn can be removed but not deleted.
can you please record a screencast showing this issue? And attach a log (Help > View log)
Here you go.
In addition the column width is not saved.23-02-_2022_14-23-53.zip (537,6 KB)
Alerts is not a separate column anymore. They appear as icons in the name column.
OK.
Still, NO settings are saved.
They will be saved if you save the file. The problem is that changing column width won’t mark the project as modified (this will be fixed), however, if you e.g. add and remove a task and save the project, the column widths will be saved too.
Submitted a new issue to the tracker: https://github.com/bardsoftware/ganttproject/issues/2024
Not really true. The added column will be saved. The width of the columns does never save.
I see, it happens if the order of the column is the same as the default order (that is, name - begin date - end date). Will be fixed too.
