What do you mean when you say “does not work”? I just have tried exporting House Building Sample project to MPX and importing the result back. It works fine.
thank you for your message. Followed error occur when I import the exported .mpx file.
Error reading file (failed at line 13)
Failed to parse date time
Unparsable date “Fr. 28.01.22”
When I import the exported .xml Microsoft Project file, the days off from 01.03.-02.04. of the resources import only the first day 01.03. It seems that the .xml is right, see followed cutout.
thank you for your message. When I change the export language for .mpx file to English, the import works. Also, the resources days off works with splitting the vacation in each day. But the earliest begin time is not including. With this knowledge you solved my problem to export files with absence of resources, days off. Thank you.
