I would like to suggest an improvement by implementing a logic that I believe is essential for the program.
Frequently, a subsequent activity that has a link starts and has its completion recorded in it (even if partial).
What happens is that, if the initial activity is postponed, it moves the subsequent activity, which creates an unrealistic situation in the project, since it has already had progress recorded.
In MS Project, when progress is recorded in subsequent tasks, it ignores the link so that it does not move any further, resolving the reported behavior.
Therefore, my suggestion is to put a condition in the program code that if progress is reported in the task, ignore the link, which will improve usability for all users!
I understand the point; however, I can see some concerns, too.
In my opinion, the case when a successor is started although the predecessor is not yet finished is âunrealisticâ as well. I added quotes because I understand that in reality, we may start working on the successor before a predecessor is done, there may be different reasons for that, however, from the project logic, I see no big difference between these two: we move a task that is already in progress vs we started a task although the predecessor is not yet done.
There may be other solutions, for instance:
remove the dependency
split the successor task in two parts
add a lag
just let it move since we donât really care if it started on this day or on some other.
Probably it makes sense to draw userâs attention to this and suggest the options.
I only use dependancy between two tasks, if the successor task can only be started, if the predecessor is truely completed (it is blocked by the predecessor).
In this special case described in this thread, I would simply remove the dependancy, as Dmitri already stated, since it doesnât exist.
There are many tasks, which start after other tasks in my charts. They start after, but can start independantly. For me the dependance is a very special case.
But thatâs my perspective. I do understand, that others may have other points on this topic, which is totally okay for me.
âThere may be other solutions, for example, we can decide to remove the dependency or split the successor task into two parts, or just let it move, since we donât care if it started on this day or some other day.â
The big problem is that if the system doesnât freeze the task, in complex schedules it is only discovered after it has moved, making it difficult to remove the dependency and discover when it actually started.
The dependency in these cases should be start to start with some delay, in practice since projects tend to be delayed there comes a time when the activity is started without the other one being completed.
My projects are very complex with many dependencies and thousands of tasks, which causes significant disorganization when they move.
Ok, so, being more strict in the tracking of progress, Iâd rather split the task. The first part would be 100% completed and that would be tracked, and the other would be available in the future. As the progress calculation is automatically calculated in summary tasks, they might both be also included in a summary task. That would be the âaccurateâ solution, but would lead to a little more deep structure in the schedule.
In fact, I usually do enter âdelaysâ as tasks to move a sequence of dependenciesâŚ
⌠and removed dependencies if a tasks is started.
