Anything I can do? GanttProject also constantly hangs and will not let me close it without a CTRL-ALT-Del + stop Java process…Tried to restart but was SOL
I can’t say that I understand what is “SOL” and how do you know that file is corrupted, but anyway, you can try recovering from auto-save files (see this comment for details: Sort by date is causing issues ) or just send the file to us by email.
With respect to “hangs”: it would be nice to see the project file.
SOL - shit out of luck…
I tried the autosave but it did not work…
I included the file, just in case…
CoachMentor_logistique2.gan (5.4 KB)
Thanks again
There are duplicated resources in the file and unfortunatly no tasks. Did you use"Import Resources" action by any chance?
File with removed resource duplicates is attached.CoachMentor_logistique2.gan (3.6 KB)
I have near exactly the same trouble: it refueses to save the fileprogramación sax.gan (7.7 KB)
and the bug traking sistem gives the followin message
C:\Users\Gustavo\ganttproject.log
GanttProject 2.8.5 Pilsen (build 2179)
java.class.path: eclipsito.jar;C:\Program Files (x86)\GanttProject-2.8
java.home: C:\Program Files (x86)\Java\jre1.8.0_144
java.ext.dirs: C:\Program Files (x86)\Java\jre1.8.0_144\lib\ext;C:\Windows\Sun\Java\lib\ext
java.io.tmpdir: C:\Users\Gustavo\AppData\Local\Temp
java.runtime.version: 1.8.0_144-b01
java.vm.name: Java HotSpot™ Client VM
java.vm.version: 25.144-b01
os.arch: x86
os.name: Windows 10
os.version: 10.0
sun.java.command: org.bardsoftware.eclipsito.Boot ganttproject-eclipsito-config.xml -log true
user.country: 419
user.dir: C:\Program Files (x86)\GanttProject-2.8
user.home: C:\Users\Gustavo
user.language: es
user.timezone: America/Buenos_Aires
Creating main frame…
- loading look’n’feels
no editor for column=2 class=interface javax.swing.Icon - loading options
- creating menus…
- creating views…
- changing language …
- finalizing…
Main frame created
Splash closed
Resizing window…
Bounds after setVisible: java.awt.Rectangle[x=-8,y=-8,width=1378,height=780]
oct 13, 2017 3:04:06 PM net.sourceforge.ganttproject.GPLogger log
INFORMACIÓN: Bounds after opening: java.awt.Rectangle[x=-8,y=-8,width=1378,height=780]
INFORMACIÓN: Bounds stored in the options: java.awt.Rectangle[x=-8,y=-8,width=1378,height=780]
oct 13, 2017 3:04:14 PM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
INFORMACIÓN: Scanning font directories…
oct 13, 2017 3:04:14 PM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFORMACIÓN: scanning directory=C:\Program Files (x86)\Java\jre1.8.0_144/lib/fonts
INFORMACIÓN: scanning directory=C:/windows/fonts
oct 13, 2017 3:04:14 PM net.sourceforge.ganttproject.GPLogger logToLogger
ADVERTENCIA: null
java.lang.StackOverflowError
at sun.util.calendar.BaseCalendar.getCalendarDateFromFixedDate(Unknown Source)
at java.util.GregorianCalendar.computeFields(Unknown Source)
at java.util.Calendar.setTimeInMillis(Unknown Source)
at java.util.Calendar$Builder.build(Unknown Source)
at sun.util.locale.provider.CalendarProviderImpl.getInstance(Unknown Source)
at java.util.Calendar.createCalendar(Unknown Source)
at java.util.Calendar.getInstance(Unknown Source)
at biz.ganttproject.core.time.CalendarFactory.newCalendar(CalendarFactory.java:35)
at biz.ganttproject.core.time.impl.FramerImpl.adjustRight(FramerImpl.java:33)
at biz.ganttproject.core.calendar.GPCalendarBase.doFindClosest(GPCalendarBase.java:101)
some 300 lines of the same…
I think you have some task start date somewhere far far in the future or in the past.
Hi, how could the error be solved?
What error? There are at lest two of them discussed in this topic.
