what is wrong with my formatting. The csv import is ignoring my predecessors and outline numbers
thanksPlanting Schedule.csv (5.9 KB)
Start dates are missing for nearly half of the tasks. It is a mandatory field at the moment, and although it can be calculated from dependencies and durations (and it should and actually it will be!), GanttProject expects to find something that looks as date in that field.
yeah, that’s what I figured. Thanks for the quick reply. I just did it manually. Look forward to the update.
cheers
Just to clarify: when I wrote “it will be” I meant that no matter what would be written in the values of “Begin date” column in CSV, GanttProject will run the scheduler and will calculate the begin dates automatically. So, you can write any reasonable dates there.
ok, so the begin date will still be needed even if there is a duration and predecessor?
Yes, at least for now.
