Custom date display
hi,
I don’t understand, in version 1.99 there is the possibility to define a custom date display, in the date column. except that it can no longer be modified, in the parameters of a task.
There is no version 1.99. There is 2.99, which is probably what you meant to say.
Can you please clarify what “can no longer be modified”? Did you mean that custom date format takes no effect in the task properties dialog?
