Custom role set name not showing up when making a new project
Following the information in
I have added a new set of Resource roles
<roles roleset-name="Default">
    <role id="0" name="undefined"/>
    <role id="1" name="project manager"/>
</roles>
<roles roleset-name="SoftwareDevelopment">
    <role id="2" name="developer"/>
    <role id="3" name="doc writer&#9;"/>
    <role id="4" name="tester"/>
    <role id="5" name="graphic designer"/>
    <role id="6" name="doc translator"/>
    <role id="7" name="packager (.rpm, .tgz, ...)"/>
    <role id="8" name="analysis"/>
    <role id="9" name="web designer"/>
    <role id="10" name="no specific role"/>
</roles>
<roles roleset-name="Project">
    <role id="11" name="optical design"/>
    <role id="12" name="optical assembly"/>
    <role id="13" name="mechanical design"/>
    <role id="14" name="mechanical assembly"/>
    <role id="15" name="electronic design"/>
    <role id="16" name="software developer"/>
    <role id="17" name="technical writer"/>
    <role id="18" name="purchasing"/>
</roles>
And things almost work as I would like. When making a project a new line for a role set appears on the step 2 page and the roles seems to be available, however the name of the role set is missing. Do I need to edit something else to get the role set name to appear?
missing_roles_name
Same problem here, the roleset name does not appear
Thanks for reporting! I submitted a new bug report:
This is fixed now. Will be available in GP 3.4
From what you describe, it looks like you’re very close already — the role sets are being parsed correctly, but the label for the roleset itself is what’s not being displayed in the UI.
In GanttProject, role sets are often not fully dynamic in the sense that custom entries are only partially supported. The application typically expects a fixed set of predefined role groups internally, and anything outside that may still load the roles, but not properly render the roleset name in the interface.
