Hi, Dmitry!
There is the following problem. After connecting to the cloud and working with documents from the cloud, the document opening dialog box (GanttProject 3.0.3002) starts to display with a damaged design (see the picture).
When delete this text
in “.ganttproject” file the problem is resolved.
Please, tell me if the problem can be solved in the current version of the program so that every time do not edit the settings file manually or should we expect a solution in the next version?
See log of program
C:\Users\user\ganttproject.log
java.class.path: eclipsito.jar;C:\Program Files (x86)\GanttProject-3.0
java.home: C:\Program Files (x86)\GanttProject-3.0\runtime
java.ext.dirs: null
java.io.tmpdir: C:\Users\user\AppData\Local\Temp
java.runtime.version: 11.0.9.1+1-LTS
java.vendor: BellSoft
java.vm.vendor: BellSoft
java.vm.version: 11.0.9.1+1-LTS
os.arch: amd64
os.name: Windows 7
os.version: 6.1
user.country: RU
user.dir: C:\Program Files (x86)\GanttProject-3.0
user.home: C:\Users\user
user.language: ru
user.timezone: Europe/Moscow
февр. 22, 2021 6:00:08 AM net.sourceforge.ganttproject.GPLogger log
февр. 22, 2021 6:00:13 AM biz.ganttproject.LoggerImpl debug
FINE: Creating main frame…
FINE: 1. loading look’n’feels
февр. 22, 2021 6:00:19 AM biz.ganttproject.LoggerImpl debug
FINE: 2. loading options
февр. 22, 2021 6:00:20 AM biz.ganttproject.LoggerImpl debug
FINE: 3. creating menus…
февр. 22, 2021 6:00:21 AM biz.ganttproject.LoggerImpl debug
FINE: 4. creating views…
февр. 22, 2021 6:00:22 AM biz.ganttproject.LoggerImpl debug
февр. 22, 2021 6:00:26 AM biz.ganttproject.LoggerImpl debug
FINE: 6. changing language …
FINE: 8. finalizing…
февр. 22, 2021 6:00:31 AM net.sourceforge.ganttproject.GPLogger log
INFO: [GanttOptions] save(): finished!!
февр. 22, 2021 6:05:25 AM net.sourceforge.ganttproject.GPLogger log
