When import CSV, the date initial and end are wrong, how fix it, I change format in Excel but nothing resolve this problem.
Please share the CSV file and the result of importing, so that we could see what is “wrong”.
Thanks. What is the result of importing? And what is the date format in the settings dialog?
so what is the date format in the settings dialog?
dd/MM/yyyy, I changed for tests, dd/MM/yy, MM/dd/yy, and mm/dd/yy or dd/mm/yy, everything don’ts worked.
You have capitalized column names: Data Inicial;Data Final
GanttProject expects the second words to be lowercased: Data inicial;Data final
Also, it appears that the files are in Windows CP-1252 encoding. I recommend using UTF-8, there must be a setting for that in Excel.
By the way, you can import Excel files directly without export to CSV step,
Thanks a lot!! About o UTF-8 yep, fixed it too, thank you
