Hi, where are the auto-save files on an OsX system?
I was working on a file yesterday and saved it and now this morning I can not open it on either Windows or Mac. I had it located on Dropbox so I could work in it from either system. There are possible problems, the project spans 2013 to 2043 right now so it is lengthy in time and also there are many entries. The *.gan file XML codes seems to be intact on a very brief scan, I just can’t get it to show up in the software.
I have tried moving the file off the Dropbox to a local drive. I tried to do the recover option.
GanttProject 3.1.3103
java.class.path: eclipsito.jar;C:\Program Files (x86)\GanttProject-3.1
java.home: C:\Program Files (x86)\GanttProject-3.1\runtime
java.runtime.version: 11.0.11+9-LTS
java.vendor: BellSoft
java.vm.vendor: BellSoft
java.vm.version: 11.0.11+9-LTS
os.arch: amd64
os.name: Windows 7
os.version: 6.1
Dec 03, 2021 1:58:05 PM biz.ganttproject.LoggerImpl error
SEVERE: Can’t set awtAppClassName (needed on Linux to show app name in the top panel)
Dec 03, 2021 1:58:05 PM net.sourceforge.ganttproject.GPLogger log
FINE: 8. finalizing…
Dec 03, 2021 1:58:07 PM net.sourceforge.ganttproject.GPLogger logToLogger
WARNING: null
java.lang.StackOverflowError
at java.base/sun.util.calendar.BaseCalendar.getCalendarDateFromFixedDate(Unknown Source)
at java.base/java.util.GregorianCalendar.computeFields(Unknown Source)
at java.base/java.util.Calendar.setTimeInMillis(Unknown Source)
at java.base/java.util.Calendar$Builder.build(Unknown Source)
at java.base/sun.util.locale.provider.CalendarProviderImpl.getInstance(Unknown Source)
at java.base/java.util.Calendar.createCalendar(Unknown Source)
at java.base/java.util.Calendar.getInstance(Unknown Source)
at biz.ganttproject.core.time.CalendarFactory.newCalendar(CalendarFactory.java:35)
at biz.ganttproject.core.time.impl.FramerImpl.adjustRight(FramerImpl.java:33)
at biz.ganttproject.core.calendar.GPCalendarBase.doFindClosest(GPCalendarBase.java:101)
at biz.ganttproject.core.calendar.GPCalendarBase.doFindClosest(GPCalendarBase.java:126)
