Good morning,
I can’t export in pdf by distributing the schedule, which is very large, on several A3 formats including the time bar and the task column. Does anyone have a solution?
Thanks for your help
Well…
For me, a schedule not only is a techical work, but usually gets to be AN ART!
Some suggestions:
- Review your WBS, and hierachy of tasks. That is why MS Project has “the timeline”, to summarize big picture.
- Check if you need to have all-in-one schedule, or might divide in “work items” with common milestones to integrate for each team.
- If your schedule is that big and cost are that complex, you might think of using a better approach for that size of schedule… and also the process of follow up!!
If you are not sure about where to start, check PMI’s guide.
Hope this helps.
