I’m a little confused: every time I allocate some resource to a task in task properties, such task showed twice on Resource chart tab for allocated resource. Is it normal? See picture. gantt_resource_allocation|476x500
Running on Kubuntu 22.04.
I can’t reproduce this issue with GP 3.2.3247. I recommend installing the latest updates and, if it is reproducible, record a screencast to demonstrate the scenario.
Turned out I’m using version 3.3.3293, but anyway, I found out how to reproduce this behavior.
Double assignment happens when I allocate resource to task via right-mouse-click context menu of the task. (I use it because it much faster then going to properties of task and then on resource tab and then select resource).
Hello, the issue is still persistent in ver 3.3.3303 - assigning resource via task right click is duplicating that assignment - and deleting the task completely only deletes one duplicate
