utilisateur debutant et pas initié aux ruses ! je n’arrive pas a parametrer enregistrer et ouvrir depuis un serveur
la connexion ftp fonctionne le test est positif par contre le serveur webdav toujours en erreur .
quelqu un peut il m’aider ? que rentrez exactement ? j’ai tout essayé
Okay, so here is the translation made by Google Translate. I am replying given this translated text which may or may not be close to original
User beginner and not initiated to tricks! I can not parameterize save and open from a server
The ftp connection works but the test is positive by the webdav server always in error.
Can anyone help me? What exactly do you get? I have tried everything
The main question: what’s the goal? Do you really need WebDAV server?
If you don’t know what is WebDAV server you probably don’t want to use it.
I really recommend to consider using Dropbox. It is free, it appears as a local folder on your machien and you can use it as a local folder from GanttProject.
