loading look’n’feels
loading options
creating menus…
creating views…
calculating size and packing…
changing language …
first attempt to restore bounds
finalizing…
Main frame created
Splash closed
Resizing window…
org.apache.http.conn.HttpHostConnectException: Connection to http://www.ganttproject.biz refused
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:190)
at org.apache.http.impl.conn.ManagedClientConnectionImpl.open(ManagedClientConnectionImpl.java:294)
at org.apache.http.impl.client.DefaultRequestDirector.tryConnect(DefaultRequestDirector.java:640)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:479)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:906)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:805)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:784)
at net.sourceforge.ganttproject.client.RssFeedChecker$4.run(RssFeedChecker.java:187)
at java.lang.Thread.run(Unknown Source)
Caused by: java.net.ConnectException: Connection timed out: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at org.apache.http.conn.scheme.PlainSocketFactory.connectSocket(PlainSocketFactory.java:127)
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:180)
… 8 more
loading options
creating menus…
creating views…
changing language …
finalizing…
Main frame created
Splash closed
Resizing window…
orge.ganttproject.GPLogger logToLogger
WARNING: Character reference "&#
org.xml.sax.SAXParseException; lineNumber: 2; columnNumber: 101; Character reference "&#
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.scanCharReferenceValue(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at net.sourceforge.ganttproject.io.XmlParser.parse(XmlParser.java:110)
at net.sourceforge.ganttproject.io.GanttXMLOpen.doLoad(GanttXMLOpen.java:102)
at net.sourceforge.ganttproject.io.GanttXMLOpen.load(GanttXMLOpen.java:96)
at net.sourceforge.ganttproject.document.ProxyDocument$ParsingState.enter(ProxyDocument.java:360)
at net.sourceforge.ganttproject.document.ProxyDocument.read(ProxyDocument.java:178)
at net.sourceforge.ganttproject.GanttProject.open(GanttProject.java:687)
at net.sourceforge.ganttproject.gui.ProjectOpenStrategy.openFileAsIs(ProjectOpenStrategy.java:119)
at net.sourceforge.ganttproject.gui.ProjectUIFacadeImpl.openProject(ProjectUIFacadeImpl.java:248)
at net.sourceforge.ganttproject.GanttProject$14.run(GanttProject.java:710)
at net.sourceforge.ganttproject.undo.UndoableEditImpl.(UndoableEditImpl.java:48)
at net.sourceforge.ganttproject.undo.UndoManagerImpl.undoableEdit(UndoManagerImpl.java:74)
at net.sourceforge.ganttproject.GanttProject.openStartupDocument(GanttProject.java:706)
at net.sourceforge.ganttproject.GanttProject$16.run(GanttProject.java:949)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Jun 23, 2020 8:49:26 AM net.sourceforge.ganttproject.GPLogger logToLogger
at net.sourceforge.ganttproject.importer.ImporterFromGanttFile.run(ImporterFromGanttFile.java:108)
at net.sourceforge.ganttproject.importer.ImporterFromGanttFile.access$100(ImporterFromGanttFile.java:49)
at net.sourceforge.ganttproject.importer.ImporterFromGanttFile$2.run(ImporterFromGanttFile.java:95)
at net.sourceforge.ganttproject.importer.ImporterFromGanttFile.run(ImporterFromGanttFile.java:92)
at net.sourceforge.ganttproject.GanttProject.tryImportDocument(GanttProject.java:736)
at net.sourceforge.ganttproject.GanttProject.access$200(GanttProject.java:91)
at net.sourceforge.ganttproject.GanttProject$14.run(GanttProject.java:713)
java.io.IOException: Character reference "&#
at net.sourceforge.ganttproject.io.XmlParser.parse(XmlParser.java:120)
INFO: Bounds after setVisible: java.awt.Rectangle[x=-8,y=-8,width=1296,height=1000]
INFO: Starting RSS check…
Jun 23, 2020 8:49:27 AM net.sourceforge.ganttproject.GPLogger log
INFO: Bounds after opening: java.awt.Rectangle[x=-8,y=-8,width=1296,height=1000]
INFO: Bounds stored in the options: java.awt.Rectangle[x=-8,y=-8,width=1296,height=1000]
Jun 23, 2020 8:49:32 AM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
Jun 23, 2020 8:49:32 AM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFO: scanning directory=C:\Program Files\Java\jre1.8.0_121/lib/fonts
Jun 23, 2020 8:49:38 AM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
Jun 23, 2020 8:50:34 AM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFO: scanning directory=/C:/Program Files (x86)/GanttProject-2.8/plugins-2.8.5/org.ganttproject.impex.htmlpdf/resource/fonts
Jun 23, 2020 8:50:34 AM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
c:\users\anfer\ganttproject.log ganttproject 3.1.3103 settings file: location: c:\users\anfer.ganttproject size:5755 is readable: true java.class.path: eclipsito.jar;c:\program files (x86)\ganttproject-3.1 java.home: c:\program files (x86)\ganttproject-3.1\runtime java.ext.dirs: null java.io.tmpdir: c:\users\anfer\appdata\local\temp\ java.runtime.version: 11.0.11+9-lts java.vendor: bellsoft java.vm.name: openjdk 64-bit server vm java.vm.vendor: bellsoft java.vm.version: 11.0.11+9-lts os.arch: amd64 os.name: windows 10 os.version: 10.0 sun.java.command: com.bardsoftware.eclipsito.launch --verbosity 1 --version-dirs plugins;~/.ganttproject.d/updates --app net.sourceforge.ganttproject.ganttproject user.country: cr user.dir: c:\program files (x86)\ganttproject-3.1 user.home: c:\users\anfer user.language: es user.timezone: america/regina may. 07, 2023 4:04:17 a. m. biz.ganttproject.loggerimpl error grave: can’t set awtappclassname (needed on linux to show app name in the top panel) may. 07, 2023 4:04:18 a. m. net.sourceforge.ganttproject.gplogger log información: deleting old auto-save files may. 07, 2023 4:04:19 a. m. biz.ganttproject.loggerimpl debug detallado: creating main frame… may. 07, 2023 4:04:19 a. m. biz.ganttproject.loggerimpl debug detallado: 1. loading look’n’feels may. 07, 2023 4:04:19 a. m. biz.ganttproject.loggerimpl debug detallado: 2. loading options may. 07, 2023 4:04:20 a. m. biz.ganttproject.loggerimpl debug detallado: 3. creating menus… may. 07, 2023 4:04:20 a. m. biz.ganttproject.loggerimpl debug detallado: 4. creating views… may. 07, 2023 4:04:20 a. m. biz.ganttproject.loggerimpl debug detallado: 5. calculating size and packing… may. 07, 2023 4:04:20 a. m. biz.ganttproject.loggerimpl debug detallado: 6. changing language … may. 07, 2023 4:04:20 a. m. biz.ganttproject.loggerimpl debug detallado: 7. first attempt to restore bounds may. 07, 2023 4:04:20 a. m. biz.ganttproject.loggerimpl debug detallado: 8. finalizing… may. 07, 2023 4:04:26 a. m. net.sourceforge.ganttproject.gplogger logtologger advertencia: trailing char < > at index 70: c:/users/anfer/onedrive/escritorio/aplicaciones informáticas/ejercicio java.nio.file.invalidpathexception: trailing char < > at index 70: c:/users/anfer/onedrive/escritorio/aplicaciones informáticas/ejercicio at java.base/sun.nio.fs.windowspathparser.normalize(unknown source) at java.base/sun.nio.fs.windowspathparser.parse(unknown source) at java.base/sun.nio.fs.windowspathparser.parse(unknown source) at java.base/sun.nio.fs.windowspath.parse(unknown source) at java.base/sun.nio.fs.windowsfilesystem.getpath(unknown source) at java.base/java.nio.file.path.of(unknown source) at java.base/java.nio.file.paths.get(unknown source) at biz.ganttproject.storage.documenturi$localdocument.createpath(document.kt:147) at biz.ganttproject.storage.recentdocasfolderitem.getbasepath(recentprojects.kt:266) at biz.ganttproject.storage.cellwithbasepath$updateitem$1.invoke(folderviewcells.kt:68) at biz.ganttproject.storage.cellwithbasepath$updateitem$1.invoke(folderviewcells.kt:60) at biz.ganttproject.storage.folderviewcell.whennotempty(folderviewcells.kt:49) at biz.ganttproject.storage.cellwithbasepath.updateitem(folderviewcells.kt:60) at biz.ganttproject.storage.cellwithbasepath.updateitem(folderviewcells.kt:58) at javafx.controls/javafx.scene.control.listcell.updateitem(unknown source) at javafx.controls/javafx.scene.control.listcell.indexchanged(unknown source) at javafx.controls/javafx.scene.control.indexedcell.updateindex(unknown source) at javafx.controls/javafx.scene.control.skin.virtualflow.setcellindex(unknown source) at javafx.controls/javafx.scene.control.skin.virtualflow.getcell(unknown source) at javafx.controls/javafx.scene.control.skin.virtualflow.getcelllength(unknown source) at javafx.controls/javafx.scene.control.skin.virtualflow.computeviewportoffset(unknown source) at javafx.controls/javafx.scene.control.skin.virtualflow.layoutchildren(unknown source) at javafx.graphics/javafx.scene.parent.layout(unknown source) at javafx.graphics/javafx.scene.parent.layout(unknown source) at javafx.graphics/javafx.scene.parent.layout(unknown source) at javafx.graphics/javafx.scene.parent.layout(unknown source) at javafx.graphics/javafx.scene.parent.layout(unknown source) at javafx.graphics/javafx.scene.parent.layout(unknown source) at javafx.graphics/javafx.scene.parent.layout(unknown source) at javafx.graphics/javafx.scene.parent.layout(unknown source) at javafx.graphics/javafx.scene.parent.layout(unknown source) at javafx.graphics/javafx.scene.scene.dolayoutpass(unknown source) at javafx.graphics/javafx.scene.scene$scenepulselistener.pulse(unknown source) at javafx.graphics/com.sun.javafx.tk.toolkit.lambda$runpulse$2(unknown source) at java.base/java.security.accesscontroller.doprivileged(native method) at javafx.graphics/com.sun.javafx.tk.toolkit.runpulse(unknown source) at javafx.graphics/com.sun.javafx.tk.toolkit.firepulse(unknown source) at javafx.graphics/com.sun.javafx.tk.quantum.quantumtoolkit.pulse(unknown source) at javafx.graphics/com.sun.javafx.tk.quantum.quantumtoolkit.pulse(unknown source) at javafx.graphics/com.sun.javafx.tk.quantum.quantumtoolkit.pulsefromqueue(unknown source) at javafx.graphics/com.sun.javafx.tk.quantum.quantumtoolkit.lambda$runtoolkit$11(unknown source) at javafx.graphics/com.sun.glass.ui.invokelaterdispatcher$future.run(unknown source) at javafx.graphics/com.sun.glass.ui.win.winapplication._runloop(native method) at javafx.graphics/com.sun.glass.ui.win.winapplication.lambda$runloop$3(unknown source) at java.base/java.lang.thread.run(unknown source)
