Hello GantProject team,
can you please help to solve my issue, I am getting an error when trying to open an MPP file !
find below the error text :
C:\Users\MMDI\ganttproject.log
java.class.path: eclipsito.jar;.
java.home: C:\Program Files\Java\jre1.8.0_301
java.io.tmpdir: C:\Users\MMDI\AppData\Local\Temp
java.runtime.version: 1.8.0_301-b09
java.vm.name: Java HotSpot™ 64-Bit Server VM
java.vm.version: 25.301-b09
os.arch: amd64
os.name: Windows 10
os.version: 10.0
sun.java.command: org.bardsoftware.eclipsito.Boot ganttproject-eclipsito-config.xml -log D:\Mes Travaux\Projet MMDI Industry\Projet ERP\MMDI_ERP_Odoo14e.mpp
user.country: FR
user.dir: C:\Program Files (x86)\GanttProject-2.6
user.home: C:\Users\MMDI
user.language: fr
user.timezone: Africa/Luanda
Creating main frame…
- loading look’n’feels
no editor for column=0 class=interface javax.swing.tree.TreeNode - loading options
- creating menus…
- creating views…
- changing language …
- changing look’n’feel …
- finalizing…
Main frame created
sept. 15, 2021 4:00:08 PM net.sourceforge.ganttproject.GPLogger logToLogger
AVERTISSEMENT: Octet 2 de la séquence UTF-8 à 2 octets non valide.
org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 1; Octet 2 de la séquence UTF-8 à 2 octets non valide.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLVersionDetector.determineDocVersion(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at net.sourceforge.ganttproject.io.GanttXMLOpen.doLoad(GanttXMLOpen.java:116)
at net.sourceforge.ganttproject.io.GanttXMLOpen.load(GanttXMLOpen.java:98)
at net.sourceforge.ganttproject.document.ProxyDocument$ParsingState.enter(ProxyDocument.java:339)
at net.sourceforge.ganttproject.document.ProxyDocument.read(ProxyDocument.java:173)
at net.sourceforge.ganttproject.GanttProject.open(GanttProject.java:605)
at net.sourceforge.ganttproject.gui.ProjectUIFacadeImpl.openProject(ProjectUIFacadeImpl.java:287)
at net.sourceforge.ganttproject.GanttProject$9.run(GanttProject.java:628)
at net.sourceforge.ganttproject.undo.UndoableEditImpl.(UndoableEditImpl.java:47)
at net.sourceforge.ganttproject.undo.UndoManagerImpl.undoableEdit(UndoManagerImpl.java:64)
at net.sourceforge.ganttproject.GanttProject.openStartupDocument(GanttProject.java:624)
at net.sourceforge.ganttproject.GanttProject.main(GanttProject.java:835)
at net.sourceforge.ganttproject.application.MainApplication.run(MainApplication.java:37)
at org.bardsoftware.impl.eclipsito.ApplicationLauncher.launchApplication(ApplicationLauncher.java:29)
at org.bardsoftware.impl.eclipsito.BootImpl$2.run(BootImpl.java:53)
Caused by: com.sun.org.apache.xerces.internal.impl.io.MalformedByteSequenceException: Octet 2 de la séquence UTF-8 à 2 octets non valide.
at com.sun.org.apache.xerces.internal.impl.io.UTF8Reader.invalidByte(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.io.UTF8Reader.read(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.load(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.arrangeCapacity(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.skipString(Unknown Source)
… 22 more
AVERTISSEMENT: Failed to read input file=D:\Mes Travaux\Projet MMDI Industry\Projet ERP\MMDI_ERP_Odoo14e.mpp
net.sf.mpxj.MPXJException: Failed to read input file=D:\Mes Travaux\Projet MMDI Industry\Projet ERP\MMDI_ERP_Odoo14e.mpp
at biz.ganttproject.impex.msproject2.ProjectFileImporter.run(ProjectFileImporter.java:184)
at biz.ganttproject.impex.msproject2.ImporterFromMsProjectFile.run(ImporterFromMsProjectFile.java:44)
at net.sourceforge.ganttproject.GanttProject.tryImportDocument(GanttProject.java:653)
at net.sourceforge.ganttproject.GanttProject.access$100(GanttProject.java:120)
at net.sourceforge.ganttproject.GanttProject$9.run(GanttProject.java:636)
Caused by: java.lang.ArrayIndexOutOfBoundsException
at java.lang.System.arraycopy(Native Method)
at net.sf.mpxj.mpp.MPPUtility.cloneSubArray(MPPUtility.java:1025)
at net.sf.mpxj.mpp.FixedData.(FixedData.java:163)
at net.sf.mpxj.mpp.FixedData.(FixedData.java:78)
at net.sf.mpxj.mpp.FixedData.(FixedData.java:61)
at net.sf.mpxj.mpp.MPP14Reader.processTaskData(MPP14Reader.java:1303)
at net.sf.mpxj.mpp.MPP14Reader.process(MPP14Reader.java:166)
at net.sf.mpxj.mpp.MPPReader.read(MPPReader.java:98)
at net.sf.mpxj.reader.AbstractProjectReader.read(AbstractProjectReader.java:66)
at biz.ganttproject.impex.msproject2.ProjectFileImporter.run(ProjectFileImporter.java:174)
… 11 more
Splash closed
