Export jpg/png or html failed and export pdf contains no gantt chart
Export jpg/png or html failed and export pdf contains no gantt chart.
When exporting to jpg/png, I got this message: Export failure. Failed subtask: Export project Width (0) and height (1675) must be > 0
Logs:
D:\Users\aqbiw\ganttproject.log
GanttProject 3.2.3247
java.class.path: eclipsito.jar;C:\Program Files (x86)\GanttProject-3.1
java.home: C:\Program Files (x86)\GanttProject-3.1\runtime
java.ext.dirs: null
java.io.tmpdir: D:\Users\aqbiw\AppData\Local\Temp
java.runtime.version: 11.0.11+9-LTS
java.vendor: BellSoft
java.vm.vendor: BellSoft
java.vm.version: 11.0.11+9-LTS
os.arch: amd64
os.name: Windows 10
os.version: 10.0
sun.java.command: com.bardsoftware.eclipsito.Launch --verbosity 1 --version-dirs plugins;~/.ganttproject.d/updates --app net.sourceforge.ganttproject.GanttProject D:\Users\aqbiw\OneDrive - Agfa Gevaert\Projects\2023\15_LU_ESCH-SUR-ALZETTE_0030069659_HYGIE_E.I. 8.2.1_Gantt_Projects_0030069659_V6.gan
user.country: BE
user.dir: C:\Program Files (x86)\GanttProject-3.1
user.home: D:\Users\aqbiw
user.language: fr
user.timezone: Europe/Paris
avr. 07, 2023 10:54:35 AM biz.ganttproject.LoggerImpl debug
PRÉCIS: Creating main frame…
PRÉCIS: 1. loading look’n’feels
PRÉCIS: 2. loading options
avr. 07, 2023 10:54:36 AM biz.ganttproject.LoggerImpl debug
PRÉCIS: 3. creating menus…
PRÉCIS: 4. creating views…
PRÉCIS: 5. calculating size and packing…
PRÉCIS: 6. changing language …
PRÉCIS: 7. first attempt to restore bounds
PRÉCIS: 8. finalizing…
avr. 07, 2023 10:54:37 AM net.sourceforge.ganttproject.GPLogger log
INFOS: Deleting old auto-save files
avr. 07, 2023 10:54:38 AM biz.ganttproject.LoggerImpl error
GRAVE: Failed to fetch updates from https://www.ganttproject.biz/dl/updates/ganttproject-3.0.json
java.util.concurrent.CompletionException: java.lang.NoSuchMethodError: ‘void com.bardsoftware.eclipsito.update.UpdateMetadata.(java.lang.String, java.lang.String, java.lang.String, java.lang.String, int, java.lang.String, boolean)’
at java.base/java.util.concurrent.CompletableFuture.encodeThrowable(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.completeThrowable(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture$UniAccept.tryFire(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.postComplete(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.postFire(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture$UniWhenComplete.tryFire(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture$Completion.exec(Unknown Source)
at java.base/java.util.concurrent.ForkJoinTask.doExec(Unknown Source)
at java.base/java.util.concurrent.ForkJoinPool$WorkQueue.topLevelExec(Unknown Source)
at java.base/java.util.concurrent.ForkJoinPool.scan(Unknown Source)
at java.base/java.util.concurrent.ForkJoinPool.runWorker(Unknown Source)
at java.base/java.util.concurrent.ForkJoinWorkerThread.run(Unknown Source)
Caused by: java.lang.NoSuchMethodError: ‘void com.bardsoftware.eclipsito.update.UpdateMetadata.(java.lang.String, java.lang.String, java.lang.String, java.lang.String, int, java.lang.String, boolean)’
at biz.ganttproject.platform.UpdateKt.showUpdateDialog(Update.kt:80)
at biz.ganttproject.platform.UpdateKt.checkAvailableUpdates$lambda-0(Update.kt:66)
… 10 more
avr. 07, 2023 10:54:58 AM org.ganttproject.impex.htmlpdf.itext.ITextEngine registerFontDirectories
AVERTISSEMENT: Failed to find directory fonts in plugin org.ganttproject.impex.htmlpdf
scheduling [email protected] group=net.[email protected]645d02f1
avr. 07, 2023 10:55:04 AM net.sourceforge.ganttproject.GPLogger log
INFOS: [ProgressMonitorImpl] begin Task: name=Running export
INFOS: [ProgressMonitorImpl] begin subTask: name=Generating PDF
INFOS: [ProgressMonitorImpl] finished subTask
INFOS: [ProgressMonitorImpl] begin subTask: name=Finalizing
INFOS: [ProgressMonitorImpl] finished Task
avr. 07, 2023 10:55:27 AM net.sourceforge.ganttproject.GPLogger log
INFOS: [ProgressMonitorImpl] begin subTask: name=Export project
avr. 07, 2023 10:55:27 AM net.sourceforge.ganttproject.GPLogger logToLogger
AVERTISSEMENT: Export failure. Failed subtask: Export project
java.lang.RuntimeException: Export failure. Failed subtask: Export project
at net.sourceforge.ganttproject.export.ExporterBase$2.run(ExporterBase.java:182)
at org.bardsoftware.impl.eclipsito.JobManagerImpl$GroupWorker.run(JobManagerImpl.java:163)
Caused by: java.lang.IllegalArgumentException: Width (0) and height (1675) must be > 0
at java.desktop/java.awt.image.SampleModel.(Unknown Source)
at java.desktop/java.awt.image.SinglePixelPackedSampleModel.(Unknown Source)
at java.desktop/java.awt.image.PackedColorModel.createCompatibleSampleModel(Unknown Source)
at net.sourceforge.ganttproject.chart.export.RenderedChartImage.(RenderedChartImage.java:49)
at net.sourceforge.ganttproject.chart.ChartRasterImageBuilder.acceptChart(PrintChartApiImpl.kt:103)
at net.sourceforge.ganttproject.chart.export.ChartImageBuilder.buildImage(ChartImageBuilder.kt:56)
at net.sourceforge.ganttproject.chart.PrintChartApiImpl.buildImage(PrintChartApiImpl.kt:55)
at net.sourceforge.ganttproject.chart.PrintChartApiImpl.exportChart(PrintChartApiImpl.kt:49)
at net.sourceforge.ganttproject.export.ExporterToImage$1.run(ExporterToImage.java:163)
at net.sourceforge.ganttproject.export.ExporterBase$2.run(ExporterBase.java:180)
… 2 more
!!! canceling family=Export job family
cleaning jobs…
… 2 more
Computer rebooted. New version installed. Same issue.
Even creating a simple new project with 2 tasks give the same problem.
Thanks for your help.
6 days later, the same behavior. Can someone helps?
It is strange that you say “GanttProject 3.2” while in the logs we see GanttProject 3.1 in the installation path. I would recommend to uninstall both versions, remove .ganttproject.d./updates folder from your home folder to remove any maintenance updates and then install the latest version and all maintenance updates.
Hi Dmitry,
I did remove both version and all folder and files from the home folder. Then reinstalled the latest version and it works fine now. Export to pic and pdf are working again. Thanks a lot.
