Hello
I am trying to export a schedule to a Microsoft Project file. I am having trouble with the following user defined columns. Can I ask for guidance on how to edit the file?
I am attaching the file in question as an attachment. The export file is in czech.
A.gan
Thank you in advance for your help
ub 13, 2022 1:10:56 ODP. net.sourceforge.ganttproject.GPLogger logToLogger
WARNING: Export failure. Failed subtask: Export project
java.lang.RuntimeException: Export failure. Failed subtask: Export project
at net.sourceforge.ganttproject.export.ExporterBase$2.run(ExporterBase.java:182)
at org.bardsoftware.impl.eclipsito.JobManagerImpl$GroupWorker.run(JobManagerImpl.java:163)
dub 13, 2022 1:12:08 ODP. net.sourceforge.ganttproject.GPLogger log
INFO: [ProgressMonitorImpl] begin Task: name=Running export
INFO: [ProgressMonitorImpl] begin subTask: name=Export project
dub 13, 2022 1:12:08 ODP. net.sourceforge.ganttproject.GPLogger logToLogger
WARNING: Some of the custom columns failed to export: [_IPOS HMOTNOST, _IPOS HMOTNOST 2]
net.sf.mpxj.MPXJException: Some of the custom columns failed to export: [_IPOS HMOTNOST, _IPOS HMOTNOST 2]
at biz.ganttproject.impex.msproject2.CustomPropertyMapping.buildMapping(CustomPropertyMapping.java:160)
at biz.ganttproject.impex.msproject2.CustomPropertyMapping.buildMapping(CustomPropertyMapping.java:58)
at biz.ganttproject.impex.msproject2.ProjectFileExporter.exportTasks(ProjectFileExporter.java:155)
at biz.ganttproject.impex.msproject2.ProjectFileExporter.run(ProjectFileExporter.java:90)
at biz.ganttproject.impex.msproject2.ExporterToMsProjectFile$2.run(ExporterToMsProjectFile.java:118)
at net.sourceforge.ganttproject.export.ExporterBase$2.run(ExporterBase.java:174)
at java.base/java.lang.Thread.run(Unknown Source)(195.6 kB)
