Good day Dmitry, sorry for the slow reply on this.
When I select Sat/Sun as the weekend and apply 'No tasks can run" option it would give this error log in the bottom left. There were a ton more entries then this so I cleared out the redundancies between the actual statements.
Thank you again for your time!
C:\Users\Serveme\ganttproject.log
GanttProject 2.8.11 Pilsen (build 2396)
java.class.path: eclipsito.jar;C:\Program Files (x86)\GanttProject-2.8
java.home: C:\Program Files (x86)\Java\jre1.8.0_261
java.ext.dirs: C:\Program Files (x86)\Java\jre1.8.0_261\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.io.tmpdir: C:\Users\Serveme\AppData\Local\Temp
java.runtime.version: 1.8.0_261-b12
java.vm.name: Java HotSpot™ Client VM
java.vm.version: 25.261-b12
os.arch: x86
os.name: Windows 10
os.version: 10.0
sun.java.command: org.bardsoftware.eclipsito.Boot -plugins-dir plugins -app net.sourceforge.ganttproject.GanttProject -log true \SUN\SunShine\100 DOCUMENTS\Daily Reports\Full company schedule.gan
user.country: US
user.dir: C:\Program Files (x86)\GanttProject-2.8
user.home: C:\Users\Serveme
user.language: en
user.timezone: America/Anchorage
Sep 22, 2020 9:10:01 AM net.sourceforge.ganttproject.GPLogger log
INFO: Options file:C:\Users\Serveme.ganttproject
Sep 22, 2020 9:10:03 AM net.sourceforge.ganttproject.GPLogger log
Creating main frame…
loading look’n’feels
loading options
creating menus…
creating views…
calculating size and packing…
changing language …
first attempt to restore bounds
Sep 22, 2020 9:10:04 AM net.sourceforge.ganttproject.GPLogger log
INFO: Bounds stored in the options: java.awt.Rectangle[x=-8,y=-8,width=1936,height=1056]
finalizing…
Main frame created
INFO: Bounds after setVisible: java.awt.Rectangle[x=-8,y=-8,width=1936,height=1056]
Splash closed
Resizing window…
INFO: Bounds after opening: java.awt.Rectangle[x=-8,y=-8,width=1936,height=1056]
Sep 22, 2020 9:10:11 AM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
Sep 22, 2020 9:10:11 AM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFO: scanning directory=C:\Program Files (x86)\Java\jre1.8.0_261/lib/fonts
Sep 22, 2020 9:10:12 AM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
Sep 22, 2020 9:10:17 AM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFO: scanning directory=/C:/Program Files (x86)/GanttProject-2.8/plugins/2.8.11/org.ganttproject.impex.htmlpdf/resource/fonts
Sep 22, 2020 9:10:17 AM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
java.lang.StackOverflowError
at sun.util.calendar.BaseCalendar.getCalendarDateFromFixedDate(Unknown Source)
at java.util.GregorianCalendar.computeFields(Unknown Source)
at java.util.Calendar.setTimeInMillis(Unknown Source)
at java.util.Calendar$Builder.build(Unknown Source)
at sun.util.locale.provider.CalendarProviderImpl.getInstance(Unknown Source)
at java.util.Calendar.createCalendar(Unknown Source)
at java.util.Calendar.getInstance(Unknown Source)
at biz.ganttproject.core.time.CalendarFactory.newCalendar(CalendarFactory.java:35)
at biz.ganttproject.core.time.impl.FramerImpl.adjustRight(FramerImpl.java:33)
at biz.ganttproject.core.calendar.GPCalendarBase.doFindClosest(GPCalendarBase.java:101)
at biz.ganttproject.core.calendar.GPCalendarBase.doFindClosest(GPCalendarBase.java:126)
Sep 22, 2020 9:10:42 AM net.sourceforge.ganttproject.GPLogger logToLogger
WARNING: null
WARNING: null
WARNING: null
