this came by email
I am using your software first time to do a Gantt chart.
I want to change the text colours of the milestones. Is there any chance I can change it, as I could not see any option for that.
this came by email
I am not sure that I clearly understand what is “text color”. If you meant text in the table columns then no, text color can’t be changed. If you meant the color of milestone diamonds on the chart then yes, you can change it in the task properties.
