This came by email
It seems that this software does not support input Chinese in ubuntu 17.10, Would you help to fix it, thank you very much!
This came by email
Chinese input is supported. If it doesn’t work for you, please provide more details and try setting Chinese language in the application settings beforehand.
me too. i use fcitx, sogou to input chinese.
Can you type chinese in any other Java application, e.g. FreeMind or jEdit? If not then you may want to choose other IM engine, such as IBus. I do not know anything about fcitx, but quick googling “fcitx java” shows that there may be issues which we can’t fix on application level.
yes, i use fcitx. and i do doubt that all the java app not worked well.
and i tried jedit. not work…
so, i will try to use ibus on ubuntu17.10 which is not supported well.
thanks anyway!!!
I updated to ubuntu18.04 and problem solved
Continuing the discussion from From Email: Chinese input:
thank you! I haven’t update my ubuntu to 18.04 because my vpn seems not working in ubuntu 18.04
