The “unlink” portion seems to be not working and make the program to some degree useless, since once you link item you can not undo it.
You can unlink two tasks using any of the following:
- Select both tasks and click unlink button above the task table
- Open successor task properties dialog and delete predecessor in the Predecessors tab.
