Export or Print does not show the color bars of the Gannt rows , any solution ?
thanks !!
thanks !!
Thanks for your answer
Yes I mean the task bars, the problem is only in the Pdf export or Print , attached a screenshot. It is only on the Gannt Chart, on the human resources Chart the bars are fine.
I was using a macbook M1, if I open the same file on a PC it works fine no problems.
What GP version are you using?
