Hi
I have a project plan made in Gantt chart. Can I import gan.file to Excel and open it in plugin?
Hi
I am not sure that I clearly understand the question, but most likely there is no such feature in GanttProject. You can export the project data to Excel. You can export the chart to PNG and insert it into Excel if you wish. That’s it.
Hi Dmitry! Thank you for your help and answer! I think you got my point, even it was poorly explained. The actual question was that can I open gantt files (charts) in Excel and modify those? If I only have raw data or picture file available from Gantt, it does not serve the purpose well, because I cannot modify the chart. Thanks anyway! This solved the problem
No, sorry
