I started GP, created new project and 2 new tasks, then left it idle for 10 minutes.
Tried save - GP closed. Below is FULL log. Note that there are no records from starting idle time (4:21) till saving (4:35)
GanttProject 2.8.1 Pilsen (build 2024)
java.class.path: eclipsito.jar;.
java.home: C:\Program Files (x86)\Java\jre1.8.0_121
java.ext.dirs: C:\Program Files (x86)\Java\jre1.8.0_121\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.io.tmpdir: C:\Users\Michal\AppData\Local\Temp
java.runtime.version: 1.8.0_121-b13
java.vm.name: Java HotSpot™ Client VM
java.vm.version: 25.121-b13
os.arch: x86
os.name: Windows 10
os.version: 10.0
sun.java.command: org.bardsoftware.eclipsito.Boot ganttproject-eclipsito-config.xml -log true
user.country: PL
user.dir: C:\Program Files (x86)\GanttProject-2.8
user.home: C:\Users\Michal
user.language: pl
user.timezone: Europe/Belgrade
maj 31, 2017 4:21:40 PM net.sourceforge.ganttproject.GPLogger log
INFO: Options file:C:\Users\Michal.ganttproject
maj 31, 2017 4:21:41 PM net.sourceforge.ganttproject.GPLogger log
Creating main frame…
- loading look’n’feels
- loading options
- creating menus…
- creating views…
- changing language …
maj 31, 2017 4:21:42 PM net.sourceforge.ganttproject.GPLogger log
INFO: Setting bounds from options: java.awt.Rectangle[x=-8,y=22,width=1696,height=1036]
- finalizing…
Main frame created
INFO: Bounds after setVisible: java.awt.Rectangle[x=-8,y=22,width=1696,height=1036]
Splash closed
Resizing window…
INFO: Bounds after opening: java.awt.Rectangle[x=-8,y=22,width=1696,height=1036]
maj 31, 2017 4:21:50 PM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
maj 31, 2017 4:21:50 PM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFO: scanning directory=C:\Program Files (x86)\Java\jre1.8.0_121/lib/fonts
maj 31, 2017 4:21:54 PM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFO: scanning directory=/C:/Program Files (x86)/GanttProject-2.8/plugins/org.ganttproject.impex.htmlpdf/resource/fonts
maj 31, 2017 4:21:54 PM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
