I installed GanttProject 3.0 (beta) to have a look, and after uninstalling it, the ‘old’ (stable) version doesn’t run anymore. The splash screen shows, but then nothing. The process keeps running, but nothing happens. I have already uninstalled 3.0 and 2.8, restarted, re-installed 2.8, but still the same… is there anything else I shoul reinstall (java?)?
thx
Most likely you need to remove the options file. It is named .gantproject and it sits in your user home folder. Note the leading dot in the name. It may be hidden by your file browser.
Out of curiosity, why did you decide to roll back to 2.8? Anything went wrong with 3.0? It would be nice to know, given that it is releasing soon.
I will have a look for the options file…
Okay it worked. Thanks for the quick reply!
I had the impression that the 2.8 version started more quickly than the 3.0, and wanted to check that (but couldn’t)… I will have a look later on if it is a right impression or not.
Is there a comparison chart of some sort, between the two versions? Or a changelog?
