GanttProject 3.2 doesn't start anymore (NoClassDefFoundError)
App worked fine, but since the ~last week, it doesn’t start / hangs on startup (only Gantt Icon appears and openjdk in task bar is visible). No Error Message.
Maybe due to windows or java update?
Tried reinstall. Gantt 2.8 is working.
other info: Java Runtime Version 8 Update 321
info from log:
GanttProject 3.2.3230
java.runtime.version: 11.0.13+8-LTS
java.vendor: BellSoft
java.vm.vendor: BellSoft
java.vm.version: 11.0.13+8-LTS
os.arch: amd64
os.name: Windows 10
os.version: 10.0
user.country: DE
user.dir: C:\Program Files (x86)\GanttProject-3.2
VORM. com.bardsoftware.eclipsito.runtime.RunLoop$1 uncaughtException
WARNUNG: [uncaughtException]java.lang.NoClassDefFoundError: biz/ganttproject/core/chart/scene/IdentifiableRow
at java.base/java.lang.ClassLoader.defineClass1(Native Method)
at java.base/java.lang.ClassLoader.defineClass(Unknown Source)
at java.base/java.security.SecureClassLoader.defineClass(Unknown Source)
at java.base/java.net.URLClassLoader.defineClass(Unknown Source)
at java.base/java.net.URLClassLoader$1.run(Unknown Source)
at java.base/java.net.URLClassLoader.findClass(Unknown Source)
at com.bardsoftware.eclipsito.runtime.BundleClassLoader.findClass(BundleClassLoader.java:128)
at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
at net.sourceforge.ganttproject.task.TaskManager$Access.newInstance(TaskManager.java:203)
at net.sourceforge.ganttproject.GanttProjectBase.(GanttProjectBase.java:191)
at net.sourceforge.ganttproject.GanttProject.(GanttProject.java:138)
at net.sourceforge.ganttproject.AppKt.startUiApp$lambda-0(App.kt:63)
Caused by: java.lang.ClassNotFoundException: biz.ganttproject.core.chart.scene.IdentifiableRow
… 39 more
it is possible that you missed one of the updates. I suggest removing .ganttproject.d/updates folder from your home directory, downloading the latest GanttProject 3.2 installer and installing it.
Nice, it worked. thank you very much.
