I’m having problem exporting pdf.
Here my report:
C:\Users\Dario\ganttproject.log
GanttProject 3.2.3230
is readable: false
java.class.path: eclipsito.jar;C:\Program Files (x86)\GanttProject-3.2
java.home: C:\Program Files (x86)\GanttProject-3.2\runtime
java.ext.dirs: null
java.io.tmpdir: C:\Users\Dario\AppData\Local\Temp
java.runtime.version: 11.0.13+8-LTS
java.vendor: BellSoft
java.vm.vendor: BellSoft
java.vm.version: 11.0.13+8-LTS
os.arch: amd64
os.name: Windows 10
os.version: 10.0
sun.java.command: com.bardsoftware.eclipsito.Launch --verbosity 1 --version-dirs plugins;~/.ganttproject.d/updates --app net.sourceforge.ganttproject.GanttProject C:\Users\Dario\Desktop\filename20.gan
user.country: IT
user.dir: C:\Program Files (x86)\GanttProject-3.2
user.home: C:\Users\Dario
user.language: it
user.timezone: Europe/Berlin
mar 27, 2022 7:31:23 AM biz.ganttproject.LoggerImpl debug
BUONO: Creating main frame…
BUONO: 1. loading look’n’feels
mar 27, 2022 7:31:24 AM biz.ganttproject.LoggerImpl debug
BUONO: 2. loading options
BUONO: 3. creating menus…
mar 27, 2022 7:31:26 AM biz.ganttproject.LoggerImpl debug
BUONO: 4. creating views…
BUONO: 5. calculating size and packing…
mar 27, 2022 7:31:27 AM biz.ganttproject.LoggerImpl debug
BUONO: 6. changing language …
BUONO: 7. first attempt to restore bounds
BUONO: 8. finalizing…
mar 27, 2022 7:32:42 AM org.ganttproject.impex.htmlpdf.itext.ITextEngine registerFontDirectories
AVVERTENZA: Failed to find directory fonts in plugin org.ganttproject.impex.htmlpdf
scheduling job=net.sourceforge.ganttproject.export.ExporterBase$2@5a303483 group=net.sourceforge.ganttproject.gui.GanttStatusBar$ProgressMonitorImpl@1c974570
mar 27, 2022 7:34:14 AM net.sourceforge.ganttproject.GPLogger log
INFORMAZIONI: [ProgressMonitorImpl] begin Task: name=Running export
INFORMAZIONI: [ProgressMonitorImpl] begin subTask: name=Generating PDF
java.lang.NullPointerException
at net.sourceforge.ganttproject.task.CustomColumnsValues.getValue(CustomColumnsValues.java:70)
at biz.ganttproject.lib.fx.TreeTableImageBuilderKt$buildImage$1.invoke(TreeTableImageBuilder.kt:74)
at biz.ganttproject.lib.fx.TreeTableImageBuilderKt$buildImage$1.invoke(TreeTableImageBuilder.kt:65)
at biz.ganttproject.ganttview.TaskTableKt.depthFirstWalk(TaskTable.kt:872)
at biz.ganttproject.lib.fx.TreeTableImageBuilderKt.buildImage(TreeTableImageBuilder.kt:65)
at biz.ganttproject.ganttview.TaskTable$initChartConnector$4$6.invoke(TaskTable.kt:267)
at org.ganttproject.impex.htmlpdf.itext.ChartWriter.acceptTable(ChartWriter.java:124)
at net.sourceforge.ganttproject.chart.export.ChartImageBuilder.buildImage(ChartImageBuilder.kt:55)
at net.sourceforge.ganttproject.chart.PrintChartApiImpl.buildImage(PrintChartApiImpl.kt:55)
at org.ganttproject.impex.htmlpdf.itext.ChartWriter.write(ChartWriter.java:74)
at org.ganttproject.impex.htmlpdf.itext.ThemeImpl.writeGanttChart(ThemeImpl.java:376)
at org.ganttproject.impex.htmlpdf.itext.ThemeImpl.writeProject(ThemeImpl.java:277)
at org.ganttproject.impex.htmlpdf.itext.ThemeImpl.run(ThemeImpl.java:258)
at org.ganttproject.impex.htmlpdf.itext.ITextEngine$3.run(ITextEngine.java:217)
at net.sourceforge.ganttproject.export.ExporterBase$2.run(ExporterBase.java:180)
at org.bardsoftware.impl.eclipsito.JobManagerImpl$GroupWorker.run(JobManagerImpl.java:163)
mar 27, 2022 7:34:15 AM net.sourceforge.ganttproject.GPLogger logToLogger
AVVERTENZA: Export failure. Failed subtask: Generating PDF
java.lang.RuntimeException: Export failure. Failed subtask: Generating PDF
at net.sourceforge.ganttproject.export.ExporterBase$2.run(ExporterBase.java:182)
Caused by: com.itextpdf.text.exceptions.IllegalPdfSyntaxException: Unbalanced save/restore state operators.
at com.itextpdf.text.pdf.PdfContentByte.sanityCheck(PdfContentByte.java:4193)
at com.itextpdf.text.pdf.PdfContentByte.toPdf(PdfContentByte.java:318)
at com.itextpdf.text.pdf.PdfFormXObject.(PdfFormXObject.java:88)
at com.itextpdf.text.pdf.PdfTemplate.getFormXObject(PdfTemplate.java:262)
at com.itextpdf.text.pdf.PdfWriter.addXFormsToBody(PdfWriter.java:1353)
at com.itextpdf.text.pdf.PdfWriter.addSharedObjectsToBody(PdfWriter.java:1364)
at com.itextpdf.text.pdf.PdfWriter.close(PdfWriter.java:1251)
at com.itextpdf.text.pdf.PdfDocument.close(PdfDocument.java:901)
at com.itextpdf.text.Document.close(Document.java:415)
at org.ganttproject.impex.htmlpdf.itext.ThemeImpl.run(ThemeImpl.java:263)
… 2 more
!!! canceling family=Export job family
cleaning jobs…
scheduling job=net.sourceforge.ganttproject.export.ExporterBase$2@a9e0c76 group=net.sourceforge.ganttproject.gui.GanttStatusBar$ProgressMonitorImpl@1c974570
mar 27, 2022 7:34:45 AM net.sourceforge.ganttproject.GPLogger log
mar 27, 2022 7:34:45 AM net.sourceforge.ganttproject.GPLogger logToLogger
… 2 more
cleaning jobs…
mar 27, 2022 7:35:01 AM com.bardsoftware.eclipsito.runtime.RunLoop$1 uncaughtException
AVVERTENZA: [uncaughtException]java.lang.NullPointerException
at net.sourceforge.ganttproject.chart.ChartRasterImageBuilder.acceptTable(PrintChartApiImpl.kt:95)
at net.sourceforge.ganttproject.chart.PrintChartApiImpl.exportChart(PrintChartApiImpl.kt:49)
at biz.ganttproject.print.PrintChartApi$DefaultImpls.exportChart$default(PrintImageProcessor.kt:44)
at biz.ganttproject.print.PrintImageProcessor.doRun(PrintImageProcessor.kt:102)
at biz.ganttproject.print.PrintImageProcessor.access$doRun(PrintImageProcessor.kt:79)
at biz.ganttproject.print.PrintImageProcessor$run$job$1.invokeSuspend(PrintImageProcessor.kt:90)
at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:106)
at kotlinx.coroutines.internal.LimitedDispatcher.run(LimitedDispatcher.kt:39)
at kotlinx.coroutines.scheduling.TaskImpl.run(Tasks.kt:95)
at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(CoroutineScheduler.kt:571)
at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(CoroutineScheduler.kt:750)
at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(CoroutineScheduler.kt:678)
at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(CoroutineScheduler.kt:665)
scheduling job=net.sourceforge.ganttproject.export.ExporterBase$2@4b3b245c group=net.sourceforge.ganttproject.gui.GanttStatusBar$ProgressMonitorImpl@1c974570
mar 27, 2022 7:37:25 AM net.sourceforge.ganttproject.GPLogger log
INFORMAZIONI: [ProgressMonitorImpl] begin subTask: name=Export project
mar 27, 2022 7:37:25 AM net.sourceforge.ganttproject.GPLogger logToLogger
AVVERTENZA: Export failure. Failed subtask: Export project
java.lang.RuntimeException: Export failure. Failed subtask: Export project
Caused by: java.lang.NullPointerException
at net.sourceforge.ganttproject.export.ExporterToImage$1.run(ExporterToImage.java:163)
… 2 more
cleaning jobs…
scheduling job=net.sourceforge.ganttproject.export.ExporterBase$2@16b8c216 group=net.sourceforge.ganttproject.gui.GanttStatusBar$ProgressMonitorImpl@1c974570
mar 27, 2022 7:37:52 AM net.sourceforge.ganttproject.GPLogger log
mar 27, 2022 7:37:53 AM net.sourceforge.ganttproject.GPLogger log
INFORMAZIONI: [ProgressMonitorImpl] finished subTask
INFORMAZIONI: [ProgressMonitorImpl] begin subTask: name=Finalizing
INFORMAZIONI: [ProgressMonitorImpl] finished Task
scheduling job=net.sourceforge.ganttproject.export.ExporterBase$2@480ff394 group=net.sourceforge.ganttproject.gui.GanttStatusBar$ProgressMonitorImpl@1c974570
mar 27, 2022 8:39:48 AM net.sourceforge.ganttproject.GPLogger log
mar 27, 2022 8:39:48 AM net.sourceforge.ganttproject.GPLogger logToLogger
… 2 more
cleaning jobs…
