I’ve downloaded GanttProject (the .zip file) and tried to run it on Fedora 33 (KDE). It just doesn’t start and it’s process stays opened, needing to be killed afterwards.
Although the ~/.ganttproject.d is created there are no files in either the logs or updates folders. I’ve tried running it through the terminal to see if it would spit some kind of information to search for the problem, but it doesn’t.
Using Oracle’s JRE, version 15.0.1+9-18
I’m stuck. Can anyone help me?
