I’ve recently updated GanttProject. Now my version is 3.2.3221. My operating system is MacOS 12.2.1 Monterey (intel version).
When I try to print, the app freezes when I click in ‘Print’ buttom (see the image below). I have to kill GanttProject and it became useless because this reason. Could you solve that issue, please?
Please post the contents of the log file. The log file is ganttproject.log and it sits in your home folder (on macOS it is usually /Users/ )
Printing is a fragile thing, and it may or may not work. You can use “export pages as ZIP” function which creates a ZIP archive with exactly the same images which would’ve be sent on printer. You can print them using other apps.
Thank you for the advice. Here it is the ganttproject.log
ganttproject.log (2,4 KB)
Is it a complete log after reproducing the freeze?
I reproduced again the freeze and then killed the app after 30 seconds of freezing. There are two log files created, named ganttproject.log and java0.log. I send you the two of them:
java0.log (1000 Bytes)
