Hi
I cannot succeed to take my ganttprojet .gan file to omniplan
Here is the omniplan error:
2024-07-26 08:50:47.983 MSPXMLFilterXPCService[21208:314776] MSPIXMLImporter: Importing XML (MSPDI) file to OP 2 document bundle…
2024-07-26 08:50:47.983 MSPXMLFilterXPCService[21208:314776] Input: ‘/Users/mattao/Documents/GanttProject/Planning des travaux du FARE METUA-V1.xml’
2024-07-26 08:50:47.983 MSPXMLFilterXPCService[21208:314776] Output: ‘/Users/mattao/Library/Containers/com.omnigroup.OmniPlan3.MSPXMLFilterXPCService/Data/tmp/Planning des travaux du FARE METUA-V1.oplx’
2024-07-26 08:50:47.984 MSPXMLFilterXPCService[21208:314776] Begin loading XML document …
2024-07-26 08:50:47.992 MSPXMLFilterXPCService[21208:314776] Process XML DOM …
2024-07-26 08:50:47.996 MSPXMLFilterXPCService[21208:314776] The main base calendar found at UID(1)
2024-07-26 08:50:47.997 MSPXMLFilterXPCService[21208:314776] Total 1 resources found.
2024-07-26 08:50:47.997 MSPXMLFilterXPCService[21208:314776] Mapping Resource UID=1 name=‘’ …
2024-07-26 08:50:47.997 MSPXMLFilterXPCService[21208:314776] Total 6 assignments found.
2024-07-26 08:50:47.997 MSPXMLFilterXPCService[21208:314776] Total 67 task(s) found.
2024-07-26 08:50:47.998 MSPXMLFilterXPCService[21208:314776] Mapping Task(UID=0): …
2024-07-26 08:50:47.998 MSPXMLFilterXPCService[21208:314776] effort=(null) duration=PT3408H0M0S start=2024-02-22T08:00:00 finish=2025-04-22T17:00:00
2024-07-26 08:50:47.998 MSPXMLFilterXPCService[21208:314776] *** Assertion failure in -[MSPIProjectMapper buildMspTasks:assignmentMap:scenario:topGroupTask:error:], MSPIProjectMapper.m:729
2024-07-26 08:50:47.998 MSPXMLFilterXPCService[21208:314776] Exception: NSInternalInconsistencyException
This does not seem like a MS Project root task.
NSAssertFile = “MSPIProjectMapper.m”;
NSAssertLine = 729;
2024-07-26 08:50:47.998 MSPXMLFilterXPCService[21208:314776] ### Importer FAILED.
Please HELP
