GanttProject & java4shell security vulnerability
Okay, so we have another security vulnerability in Java: java4shell
In short, you’re at risk if you read a specific kind of data (namely, base64-encoded data) from untrusted sources. GanttProject normally reads data of that kind only from trusted sources - our website or GanttProject Cloud.
So, unless you store your projects on an untrusted WebDAV server, you should not panic. However, we will build GanttProject packages with the updated Java Runtime, and we advise you to upgrade as soon as they are available.
GanttProject Cloud runs on Google App Engine where the appropriate security measures were taken by Google.
