GanttProject Not Start
After severals tried i can’t get GanttProject running on Windows 11.
I used ganttproject-3.2.3230.exe and ganttproject-3.2.3230.zip without any success.
The only things is the “GanttProject Launcher (32bits)” line in the task manager but nothing appear even the splash screen.
C:\Users\xxx>java -version
openjdk version “11.0.17” 2022-10-18 LTS
OpenJDK Runtime Environment (build 11.0.17+7-LTS)
OpenJDK 64-Bit Server VM (build 11.0.17+7-LTS, mixed mode)
C:\Users\xxx>echo %JAVA_HOME%
C:\Program Files\BellSoft\LibericaJDK-11\
I even tried to unactived all the security on the machine.
Thanks for your help.
Did you install Liberica Full JDK/Full JRE?
I think only JDK because with this link, we can only install the JDK :
https://bell-sw.com/pages/downloads/
I missed something?
EDIT : I used the bellsoft-jdk11.0.17+7-windows-amd64.msi package
There is a “package” dropdown which allows for choosing what you download. You need “Full JRE” package. Here is a direct link for your convenience:
https://download.bell-sw.com/java/11.0.17+7/bellsoft-jre11.0.17+7-windows-amd64-full.msi
So i have done the install and now :
C:\Users\xxx>echo %java_home%
C:\Program Files\BellSoft\LibericaJRE-11-Full\
but even after a restart of windows same things : GanttProject don’t start and no splahscreen
Please post what is printed in the command line window when you run ganttproject.bat.
Of course :
nov. 14, 2022 1:20:09 PM com.bardsoftware.eclipsito.runtime.ModuleRuntime lambda$getVersionLayerStoreDirs$5
PR╔CIS: Path `plugins` is not absolute. We'll try resolving it relative to user.dir=C:\Users\xxx\Downloads\ganttproject-3.2.3230
nov. 14, 2022 1:20:09 PM com.bardsoftware.eclipsito.runtime.ModuleRuntime build
PR╔CIS: We will run with the following plugins:
nov. 14, 2022 1:20:09 PM com.bardsoftware.eclipsito.runtime.ModuleRuntime lambda$build$3
PR╔CIS: Plugin biz.ganttproject.app.localization-3.2.3240 at C:\Users\xxx\.ganttproject.d\updates\update-3240\biz.ganttproject.app.localization\plugin.xml
PR╔CIS: Plugin org.ganttproject.impex.htmlpdf-3.1.3103 at C:\Users\xxx\.ganttproject.d\updates\update-3103\org.ganttproject.impex.htmlpdf\plugin.xml
PR╔CIS: Plugin net.sourceforge.ganttproject-3.2.3240 at C:\Users\xxx\.ganttproject.d\updates\update-3240\ganttproject\plugin.xml
PR╔CIS: Plugin biz.ganttproject.core-3.2.3240 at C:\Users\xxx\.ganttproject.d\updates\update-3240\biz.ganttproject.core\plugin.xml
nov. 14, 2022 1:20:09 PM com.bardsoftware.eclipsito.runtime.Runner run
PR╔CIS: Command line args: [-log, true]
nov. 14, 2022 1:20:09 PM com.bardsoftware.eclipsito.runtime.DependencyResolver markAndSweep
GRAVE: Plugin biz.ganttproject.app.libs which is required by biz.ganttproject.core not found. Plugin C:\Users\xxx\.ganttproject.d\updates\update-3240\biz.ganttproject.core\plugin.xml will be ignored
GRAVE: It seems that dependency on plugin biz.ganttproject.core from plugin net.sourceforge.ganttproject makes a cycle. Plugin C:\Users\xxx\.ganttproject.d\updates\update-3240\ganttproject\plugin.xml will be ignored
GRAVE: It seems that dependency on plugin net.sourceforge.ganttproject from plugin biz.ganttproject.app.localization makes a cycle. Plugin C:\Users\xxx\.ganttproject.d\updates\update-3240\biz.ganttproject.app.localization\plugin.xml will be ignored
GRAVE: It seems that dependency on plugin biz.ganttproject.core from plugin org.ganttproject.impex.htmlpdf makes a cycle. Plugin C:\Users\xxx\.ganttproject.d\updates\update-3103\org.ganttproject.impex.htmlpdf\plugin.xml will be ignored
PR╔CIS: Launching application=net.sourceforge.ganttproject.GanttProject
I tried to start GanttProject 3.1 and i have no problem with this version
It seems that there is a weird mix of GanttProject components and updates on your system. Please remove C:\Users\xxx\.ganttproject.d\updates, uninstall both GP 3.1 and 3.2 and then install GanttProject 3.2 again. It is bundled with Java Runtime, and unless there is even more weird misconfiguration, it should use the bundled JRE.
Oh yeah ! Thanks, that’s working :slight_smile:
Hi there, Same problem.
I tried to run GanttProject 3.2.3240, and is not working. whenever i use the launcher is in the task manager but not working.
I follow the steps described in the discussion, install the JDK, remove the C:\Users\xxx.ganttproject.d\updates, and install everything again.
I can only open it using the ganttproject.bat, And it looks that is working. it posible to solve the Launcher properly?
Attached the command line window:
may. 31, 2023 9:56:04 A. M. com.bardsoftware.eclipsito.runtime.ModuleRuntime lambda$getVersionLayerStoreDirs$5
DETALLADO: Path plugins is not absolute. We’ll try resolving it relative to user.dir=C:\Program Files (x86)\GanttProject-3.2
may. 31, 2023 9:56:04 A. M. com.bardsoftware.eclipsito.runtime.ModuleRuntime build
DETALLADO: We will run with the following plugins:
may. 31, 2023 9:56:04 A. M. com.bardsoftware.eclipsito.runtime.ModuleRuntime lambda$build$3
DETALLADO: Plugin biz.ganttproject.impex.msproject2-3.2.3230 at C:\Program Files (x86)\GanttProject-3.2\plugins\base\biz.ganttproject.impex.msproject2\plugin.xml
DETALLADO: Plugin org.ganttproject.chart.pert-3.2.3230 at C:\Program Files (x86)\GanttProject-3.2\plugins\base\org.ganttproject.chart.pert\plugin.xml
DETALLADO: Plugin biz.ganttproject.app.localization-3.2.3246 at C:\Users\German Hermida.ganttproject.d\updates\update-3246\biz.ganttproject.app.localization\plugin.xml
DETALLADO: Plugin org.ganttproject.impex.htmlpdf-3.2.3247 at C:\Users\German Hermida.ganttproject.d\updates\update-3247\org.ganttproject.impex.htmlpdf\plugin.xml
DETALLADO: Plugin biz.ganttproject.impex.ical-3.2.3230 at C:\Program Files (x86)\GanttProject-3.2\plugins\base\biz.ganttproject.impex.ical\plugin.xml
DETALLADO: Plugin net.sourceforge.ganttproject-3.2.3247 at C:\Users\German Hermida.ganttproject.d\updates\update-3247\ganttproject\plugin.xml
DETALLADO: Plugin biz.ganttproject.app.libs-3.2.3230 at C:\Program Files (x86)\GanttProject-3.2\plugins\base\biz.ganttproject.app.libs\plugin.xml
DETALLADO: Plugin biz.ganttproject.core-3.2.3246 at C:\Users\German Hermida.ganttproject.d\updates\update-3246\biz.ganttproject.core\plugin.xml
may. 31, 2023 9:56:04 A. M. com.bardsoftware.eclipsito.runtime.Runner run
DETALLADO: Command line args: [-log, true]
DETALLADO: Launching application=net.sourceforge.ganttproject.GanttProject
InteropFactory: cannot load com.sun.javafx.embed.swing.newimpl.InteropFactoryN
I see that it tries to load plugins from your C:/Users/German Hermida/.ganttproject.d/updates/ folder and there is a weird mix of plugins from different versions. Please remove the whole folder.
