malcaraz
(Manuel)
November 10, 2023, 4:08pm
1
Hello! Using GP beta v3.3.3294 with portable JRE v17.0.9. on Win10
Exporting a PNG chart does not get the dates set in the dialog.
Exporting to a PDF chart does not show the “alert” field, as it is show in the list of visible columns.
Hope that I am not doing something wrong… Great thanks! Regards. M.
malcaraz:
Is it what is addressed in this issue?
opened 04:00PM - 01 Mar 22 UTC
closed 01:33PM - 22 Jan 24 UTC
bug
Export
Fixed and published
I notice that when exporting in JPEG format, the end date is not respect… ed and there are days/weeks in addition.
Thank you for your help.
malcaraz
(Manuel)
November 15, 2023, 4:10pm
3
Yes. Seems very similar to that description. I am using a Spanish Win10 and PORTABLE JRE… if it helps.
malcaraz
(Manuel)
January 18, 2024, 12:42pm
4
On the same issue… I cannot check the text associated with the ALERT ICONS; the width of the column is always short to show all the description. I see “NOT…”, “INP…”, “DEA…”, with Spanish UI set.
How can the fields be read? In GP, they are just icons… Thank you!
I don’t understand this, sorry. Where are those columns? What do you mean as “check”?
malcaraz
(Manuel)
January 18, 2024, 3:32pm
6
Hello @DmitryBarashev ! Thanks for replying.
I mean, “check” the text. See attached image of an PDF from a
GP v3.3 export with Alert icons.
malcaraz
(Manuel)
January 23, 2024, 9:03am
7
I mean… How can that text be changed? It also seems that it is not Spanish in the report… (i.e. “day” vs “día”, “DEA…” etc… Thank you @DmitryBarashev
I don’t see any alert column in PDF export at all in GP 3.3 (I don’t see it in GP 3.2 either).
malcaraz
(Manuel)
January 23, 2024, 2:29pm
9
Surprise! I use PORTABLE versions of GP v3.1 v3.2, v3.3 with corresponding JRE v11 and v17.
Do you think that this new column shown is a lateral effect from this configuration?
