A Java update happened [which I foolishly accepted for no reason] and GanttProject is now not starting. I get a window labeled GanttProject, but there is nothing in it. I downloaded the installer and reinstalled, but that did not help. I went to the directory where the software is installed and looked for a log file. Did not see one, but I did see a BAT file so I started a shell and ran the batch file. The file attached shows what happened before the hang.
No obvious errors. It scans some directories for fonts, including ones which aren’t on this Windows 7 laptop. The hang happens after “INFO: scanning font directories completed”
How should I try to track down the error?
Many thanks!
cmwd
log.txt (3.9 KB)
