Is there an easy way to extract assignments from the CSV file?
For example if I have 2 or more resources with different unit loadings can I get them in individual columns?
Did you mean “can GanttProject generate them in individual columns” or “is it possible technically to refactor CSV files produced by GanttProject using some other tools”? In the former case, no. In the latter, surely yes. Not sure if you need any my recipes, though, because they all involve manipulations with Linux command-line utilities.
Hi Dmitry,
thanks for that answer it was the former
Not to worry I am learning how to extract the data ![]()
