Hello
I did not got, how to make ganttprojekt to use a locally only installed JRE:
W10/64 with JPortable/openJKD-portable with no system-wide java_home
I see the starting-script but did not find the place to fill the full path to the java.exe.
Any advice is welcome.
mh
I am not sure that I completely understand what is “locally only installed JRE” but anyway, if we’re talking about Windows and ganttproject.bat
, here is a direct link to the place where it sets the full path to java.exe
: https://github.com/bardsoftware/ganttproject/blob/master/ganttproject-builder/ganttproject.bat#L5
If you set JAVA_HOME
just above this line, it will launch java.exe
from the path specified by JAVA_HOME
Yes, filling in this line
set “JAVA_HOME=c:\portableapps\commonfiles\java”
worked like a charm - thanks
mh
