Unable to load java runtime environment is error I get when trying to install. can you recommend what steps I need to take to prepare my computer
You need to install Java Runtime
Hey all - I pasted my solution in a different project in GitHub. My error was “Unable to load Java Runtime Environment” after installing GanttChart on Mac OSX when the current JDK was most certainly installed ![]()
The problem? Basically, the JavaAppLauncher is looking for libjli.dylib in the wrong location.
Solution is easy-peasy…see my writeup at [Mac OS X] To open "this Java application" you need to install the legacy Java SE 6 runtime. · Issue #160 · jpype-project/jpype · GitHub
Enjoy!
We have a knowledge base article on macOS issues and a couple of alternative distros which do not use JavaAppLauncher (described in the knowledge base)
