I use Gant as Portable APP because I can’t install anything on my PC. When I get to the window export, the export-assisten windows opens. I can choose the fomat. For example .pdf, than I get a window with other options as range, paper format, …but I can’t choose the botton OK (it turns from black into gray )…and I must abandon the assistent…
It seems I am the only one with this problem. Is it a bug of the portable version?
Any help? THANK you in advantage!
